March 11, 20242 yr comment_34613 My remote seems to be locking up when the power button is pressed multiple times within a short period of time. I then have to remove the batteries, wait a few seconds, and then put them back in. I think that this may be due to the macros. I have a macro to send a power on command to the device and change the input on the receiver and one that sends the power off command and also changes the receiver input. I have attached my configuration. Remote Model SKIP.1S.RELEASE.A06 Firmware 4.12.13-0-g1393fac Skip App 0.9.965.7346 [Nightly] Couch Commander 6000.skip Report
March 12, 20242 yr comment_34624 I have had some similar experiences. I have macros on three of the color buttons that shut off a box and switch to another HDMI, then I would press the new activity key, then do the same color button to power on the box for the new activity. I think I went a little too quick pressing the activity button before the macro had finished and the remote locked up. If I make sure to wait until the LEDs stop before continuing my sequence, it seems okay. Report
March 17, 20242 yr Author comment_34764 On 3/12/2024 at 11:35 AM, Daniel Ethier said: I have had some similar experiences. I have macros on three of the color buttons that shut off a box and switch to another HDMI, then I would press the new activity key, then do the same color button to power on the box for the new activity. I think I went a little too quick pressing the activity button before the macro had finished and the remote locked up. If I make sure to wait until the LEDs stop before continuing my sequence, it seems okay. That seems to be my issue as well. I don't think it was a problem until I updated my config a few weeks back, and at that point the firmware and app were several versions behind. Report
March 19, 20242 yr comment_34782 On 3/12/2024 at 11:35 AM, Daniel Ethier said: I have had some similar experiences. I have macros on three of the color buttons that shut off a box and switch to another HDMI, then I would press the new activity key, then do the same color button to power on the box for the new activity. I think I went a little too quick pressing the activity button before the macro had finished and the remote locked up. If I make sure to wait until the LEDs stop before continuing my sequence, it seems okay. And it happened again. I was watching my Apple TV and wanted to switch to my Nextgen TV box on HDMI 1. So I did the yellow color button, waited until the LEDs stopped, and pressed the A button, but the remote was locked up. I had to remove the batteries and replace them. Then it worked again. The macro on the yellow button is shown in the attached image. Seems pretty simple. Report
