Feature request: switch between button presets with letter buttons
I'd love to see an option to have the letter-buttons not act as Activity-macros but instead have them switch between different remote presets. For example, button "A" would load the button presets to control my TV, while "B" would switch the button assignments of the remote a completely different preset that allows me to control my HTPC.
I have some devices that can't be properly controlled via CEC signals. If the directional buttons of the Skip 1s are set to control the TV itself, I don't have a way to send directional inputs to the HTPC because the device can't receive the CEC signals from the TV. In those instances I could switch the button assignments over to a preset which uses IR-signal for the HTPC instead.
map the buttons with one remote for each activity... where is the problem?
