November 15, 20232 yr comment_31806 Hi, I have managed to get my remote working with bluestacks which is an android emulator for windows. I disabled virtual keyboard in the software android settings to enable the physical keyboard. However, when navigating the only way to select a video on youtube is by left clicking on the mouse. AFAIK no other key will allow it to be selected. Navigation does work with up down left right. Since windows allows you to use mouse keys, I could use numpad 5 as a physical left mouse click. However the flirc software's full keyboard only seems to show 84 keys and not the full 104 keys on a full keyboard with numpad. Does anyone have a solution? -Jeremy Report
November 15, 20232 yr Author comment_31807 I found a work around for my setup. I've attached the file and website from source forge. https://sourceforge.net/projects/vjoy-controller/files/latest/download It's a little UN-intutive in the beginning. Don't forget to add a vkeyboard, and vmouse to simulate keyboard and mouse clicks or movement. Virtual Controller v1072 Setup.exe bluestacks_vjoy.bak.vcd Report
