I started to record keys and when I made a mistake and wanted to clean an erroneous key, i noticed that delete_index seems to be broken.
$ flirc_util settings
flirc_util version 26e271e49325ec7e449a705e4d438c7d0426fd0d [26e271e+]
 Firmware Detected
 FW Version: v4.9.7
    SKU:     Flirc 2.0 [dori]
    Branch:  release
    Config:  release
    Hash:    0x1DE23EB8
Settings:
  sleep detection:  always enabled
  noise canceler:   always enabled
  inter-key delay:  N/A for current firmware
  variant:          Flirc
  builtin profiles: NA
  Memory Info:      NA
  product sku:      Flirc 2.0 [dori]
Recorded Keys:
Index  hash       IK   ID  key
    0  5EDD5604   108  01  a
$ flirc_util delete_index 0
 Firmware Detected
 FW Version: v4.9.7
    Branch:  release
    Config:  release
    Hash:    0x1DE23EB8
Settings:
  variant:          Flirc
  Memory Info:      NA
Recorded Keys:
    0  5EDD5604   108  01  a
I believe 4.9.7 is the very latest version of the firmware. I'm using flirc_util from the latest version of the https://github.com/flirc/sdk
Thanks,
  • 6 months later...
  • 9 months later...
I see the same result with flirc_util 3.27.15+ and the following Flirc 2.0 USB firmwares:
v4.9.6
v4.10.5
The workaround is to either re-format and re-record the keys, or restore a config, or delete the named key (needs the remote used to record it):
flirc_util delete <keyname>
I have written a bash script which will enumerate the current settings so that you can at least re-prompt for each key quickly.
