Help with broken Flirc. undefined symbol: libusb_get_port_number
Steve Goodey
I wonder if someone can help me?
I have a Mythbuntu system where flirc was working ok.
ubuntu update-manager offered some updates which I took. I know!!!
Unfortunately about the same time I was trying to sort a problem with screen blanking so I don't know if something I did to do with that broke flirc.
Now flirc is not working.
steve@mythbuntu:~/Flirc$ ./Flirc
QGtkStyle was unable to detect the current GTK+ theme.
fl_open_devices(333): trying to open: 20A0 :: flirc.tv
[D] fl_open_devices(379):
8087:8008 (bus 1, device 2)
8087:8000 (bus 2, device 2)
1241:1166 (bus 3, device 2)
046d:0b07 (bus 3, device 3)
2013:024f (bus 3, device 4)
2013:024f (bus 3, device 5)
20a0:0000 (bus 3, device 6)
0403:6001 (bus 3, device 7)
05e3:0722 (bus 3, device 8)
1d6b:0002 (bus 1, device 1)
1d6b:0002 (bus 2, device 1)
1d6b:0002 (bus 3, device 1)
1d6b:0003 (bus 4, device 1)
046d:c71e (bus 3, device 9)
046d:c71f (bus 3, device 10)
fl_open_devices(333): trying to open: 20A0 :: claylogic.com
fl_open_devices(396): claiming interface 0
[D] fl_open_devices(422): Vendor: claylogic.com
[D] fl_open_devices(442):  [Vendor Match]
./Flirc: symbol lookup error: ./Flirc: undefined symbol: libusb_get_port_number
steve@mythbuntu:~/Flirc$ dmesg | grep claylogic
[    1.985896] usb 3-10: Manufacturer: claylogic.com
steve@mythbuntu:~/Flirc$steve@mythbuntu:~/Flirc$ uname -a
Linux mythbuntu 3.8.0-35-generic #52~precise1-Ubuntu SMP Thu Jan 30 17:24:40 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
The message about GTK+ theme is because I've ssh'd into the box to copy error message across to a laptop.
Can anyone suggest what cause of undefined symbol: libusb_get_port_number is?
I get the same error if I run ./Flirc as sudo
Thanks, Steve
I'm having the same problem with openSuse 13.1. I'm using Flirc-v1.2.2-x64. I've got libusb-1_0-0-1.0.9-8.1.2.x86_64.rpm installed, as well as every other rpm beginning with "libusb". Doing "nm -D /usr/lib64/libusb-1.0.so.0.1.0" shows several other functions beginning with libusb, so I'm guessing I need a newer version of the libusb libraries.
~/Flirc-v1.2.2-x64> nm -D /usr/lib64/libusb-1.0.so.0.1.0 |grep libusb_get
0000000000004e20 T libusb_get_active_config_descriptor
0000000000003140 T libusb_get_bus_number
0000000000004fb0 T libusb_get_config_descriptor
0000000000005230 T libusb_get_config_descriptor_by_value
0000000000004170 T libusb_get_configuration
0000000000003410 T libusb_get_device
0000000000003150 T libusb_get_device_address
0000000000004d40 T libusb_get_device_descriptor
00000000000032a0 T libusb_get_device_list
0000000000003160 T libusb_get_device_speed
0000000000003b30 T libusb_get_max_iso_packet_size
0000000000003ab0 T libusb_get_max_packet_size
00000000000062d0 T libusb_get_next_timeout
0000000000006af0 T libusb_get_pollfds
00000000000052b0 T libusb_get_string_descriptor_ascii
0000000000004400 T libusb_get_version
~/Flirc-v1.2.2-x64>
I found that flirc was still working as a remote receiver, just that I can't now program it on my Mythbuntu system due to the above error. But moving it onto another Linux system I have, and running the Flirc GUI on that, I can program it fine.
So I'm back up and running.
Thanks to tjteixeira for responding.
Steve.
