flirc stops working on xbmc after few seconds
pdav
I'm using flirc wirh xbmc on windows 8.
I've installed the last software and forced upgrade firmware.
Flirc works on windows screen but when I launch xbmc flirc stops to work after 5-10 seconds. I have to exit xbmc or return to desktop for flirc works again.
What can I do to fix it?
Thanks a lot.
I wonder.... Is the setting, remote sends keyboard presses checked on?
maybe I need to re-upgrade to Win8 to test stuff.  I had it installed when the upgrade was $15 but it was so unstable and full compatibility issues that I went right back to Win7 inside of a week.  But I plan on Dual-booting SteamOS on my HTPC soon and care more about that.  :P
ANYWAY!   If it works, then it obviously works, but there seems to be a compatibility issue somewhere.  What's your version of XBMC?
