Sign in to follow this
memeteam
Disable LED on Flirc SE?
Unfortunately there's not. It's directly connected to the USB port's power pins. You can use an electrical tape for example, to dampen the LED's brightness. Cut out a square and tape it over the LED. You can also use multiple layers to make it even dimmer.
