November 4, 20178 yr comment_14497 What is the thickness of the gen 2 case thermal pad in millimeters? I would like to use an aftermarket thermal pad. Edited November 11, 20178 yr by Dragnerok_X Report
November 21, 20178 yr comment_14561 Just got mine and the thermal pad is 1.75-1.80mm with the ashesive cove plastic still on. My guess is 1.50mm with the plastic removed. Report
November 22, 20178 yr Author comment_14564 Thank you for taking the time to measure it. I ended up using a 1.50mm pad, which I can confirm works flawlessly. Report
