FLIRC maps wrong keys. After mapping "eject" key on "PS4" to a remote code, it presses "vol+".
received my flirc v2 today.
Installed everything and updated firmware (Flirc-Setup-3.27.19.exe).
I mapped the "eject" key on "ps4 template" to a remote code from my "tbs remote".
When i then press the key on the "tbs remote", in the flirc software, it shows "ch+" key, instead of the selected "eject" key on the ps4 template.
This happens to many other buttons too!
I map a key from the "tbs remote "to a specific key on the ps4 template BUT after, when pressing the button, it only presses the "ch+" key in the ps4 template.
So, in this state flirc is unusable for me because 90% of the mapped buttons from my "tbs remote" all press the "ch+" key.
What must i do, that, after mapping a remote code, the selected key is then "used", and not a different key?
This is the "tbs remote":
IR debugging log:
https://pastebin.com/6VJtr0DX
Ad these are the "nec" remote codes, i get, when using it with libreelec/coreelec on a s905 box:
https://pastebin.com/iaup3QUc
EDIT: Now i used my samsung tv remote. same behaviour. i map smthg to the eject key on the ps4 template but after it presses the ch+ key.
Edited by thomaz
Now i made this, from this manual
3.27.19
FW Version: v4.10.7
   SKU:     Flirc 2.0 [dori]
   Branch:  release
   Config:  release
   Hash:    0x71266B92
Settings:
  sleep detection:  always enabled
  noise canceler:   always enabled
  inter-key delay:  N/A for current firmware
  variant:          Flirc
  builtin profiles: NA
  Memory Info:      NA
  product sku:      Flirc 2.0 [dori]
Recorded Keys:
Index  hash       IK   ID  key
    0  85407C1B   052  02  0x04
    1  D74BCEC9   130  02  0x05
    2  A4B660C9   051  02  0x06
    3  D2B872C9   052  02  0x07
    4  42DBE0C9   051  02  0x08
    5  672860C9   052  02  0x09
    6  E0ABF2C9   051  02  0x0A
    7  50CF60C9   052  02  0x0B
    8  751BE0C9   052  02  0x0C
    9  A50F84C9   052  02  0x0D
   10  1532F2C9   051  02  0x0E
   11  397F72C9   051  02  0x0F
   12  DB20F2C9   052  02  0x10
   13  4BE2E0C9   051  02  0x11
   14  B6D472C9   051  02  0x12
   15  12E83CC9   052  02  0x13
   16  0FA7F2C9   051  02  0x14
   17  A2C4CEC9   051  02  0x15
   18  7E784EC9   051  02  0x16
   19  E53F4EC9   051  02  0x17
   20  E052CEC9   052  02  0x18
   21  428672C9   051  02  0x19
Then i inserted the stick to my windows kodi piers machine.
I installed the flirc addon + kodis "keymap editor"
In flirc addon only Buttons "nothing to map"
Keymap editor also doesnt get smthg when i try to "edit" a key
The final question is, how can i make such a programmed remote (e.g. "0  85407C1B   052  02  0x04") to work in kodi on windows?
Edited by thomaz
3.27.19
FW Version: v4.10.7
   Branch:  release
   Config:  release
   Hash:    0x71266B92
Settings:
  variant:          Flirc
  Memory Info:      NA
Recorded Keys:
What actually happens in the PS4? I would actually say this is a GUI bug that's highlighting the wrong key, but FLIRC is still sending the correct key to the computer.
Nope, i tried to assign smthg to the eject key but after "recording" it playbacks the ch+ key.
Same went to the kodi template, i assigned some buttons but playbacked ch+ too. only
And finally in kodi it also just only did ch+ actions.
I have german keyboard layout everyhwere. can this cause it?
No matter ... then i explorerd "flirc_util.exe" and ... ... all worked. :)
Thx a lot.
