Skip 1s – No IR output (fails camera + FLIRC USB tests)
I just received a new Skip 1s remote and it appears the IR transmitter is dead, although the remote itself is detected and configurable.
Works:
  • Skip app detects button presses.
  • I can add devices/remotes.
  • Config sync to the Skip 1s completes without errors.
Doesn’t work:
  • Skip 1s doesn’t control any devices (TV/AVR/etc.), even at close range.
  • FLIRC USB (which sees other remotes fine) receives no signal at all from the Skip 1s.
  • All remote tests during setup fail; I never get a response from any device.
Tests performed:
  1. Phone camera IR check
    • Tried both front and rear cameras.
    • Pointed at the Skip 1s IR LED area, pressed various buttons.
    • See no IR flashes from the Skip 1s, while other remotes are clearly visible on the same phone.
  2. FLIRC USB
    • FLIRC USB on PC detects IR from other remotes without issue.
    • When aiming Skip 1s at FLIRC and pressing buttons, no signal is detected.
    • Tried multiple activities, buttons, and re-synced the config.
  3. Simple config sanity check
    • Created a minimal profile with a common TV brand, mapped Power/Volume, synced.
    • Still: no device control, no visible IR on camera, no IR seen by FLIRC USB.
Given:
  • Other remotes’ IR is visible on my phone and detected by FLIRC,
  • The Skip 1s shows no IR output at all (camera + FLIRC),
I suspect a hardware fault in the IR transmitter or its driver.
Before I return it / request an RMA, is there anything else I should try?
  • Any additional firmware/reset steps? (It updated automatically when first plugged in.)
  • Any diagnostics mode or LED behavior to check?
  • Any known issues with IR output on certain units?
System details:
  • Skip 1s: brand new, received today
  • Firmware: 4.14.1-0-gdea1347
  • Skip app: SkipApp-0.9.995.10457-Beta-x64
  • OS: Windows 11
Thanks for any guidance. I just want to confirm I’m not missing anything obvious before sending it back.
Solved by jason
  • 2 months later...
