January 9Jan 9 comment_43313 I have a weird problem with the power button on the Skip 1s. I've tried to sync various different device-types and all has the problem: When I have assigned a device and test it using Flirc USB, power button does not work. All other buttons transmit something but the power button stays quiet. However I can see the remote light up so it senses that I've pressed the button. If I test the button from within the Skip app, everything is OK, the receiver get's a code. However not when I press the power button. Anybody got a clue? Everything is brand new, got it 2 days ago. Remote model: Skip.1s.Release.06, firmware: 4.13.9-0-g114437a, app: skip-app_0.9.995+10457, linux Report
January 9Jan 9 comment_43314 49 minutes ago, Niels Ole Kirkeby said: I have a weird problem with the power button on the Skip 1s. I've tried to sync various different device-types and all has the problem: When I have assigned a device and test it using Flirc USB, power button does not work. All other buttons transmit something but the power button stays quiet. However I can see the remote light up so it senses that I've pressed the button. If I test the button from within the Skip app, everything is OK, the receiver get's a code. However not when I press the power button. Anybody got a clue? Everything is brand new, got it 2 days ago. Remote model: Skip.1s.Release.06, firmware: 4.13.9-0-g114437a, app: skip-app_0.9.995+10457, linux Can you attach your support file? Hold down space bar, click the three dots, and click leave feedback (all while holding spacebar) I'll take a look. Report
January 10Jan 10 Author comment_43315 Thanks for returning. I've done it right now but there was no feedback from the program while I did it, thus I'm not sure whether it has send anything? Report
January 10Jan 10 Author comment_43316 Does the program anything anywhere? I can't find anything? Report
January 10Jan 10 Author Solution comment_43317 Hi again. As I wrote earlier, I used the Linux app to setup everything. (I've been using Linux professionally and as a hobby for almost 35 years, since it came on about a 100 floppies :-) Thus it was the natural choice) I've since tried using the Windows app which came up with a firmware update for the Skip. After the firmware update, the power button started to work, both when programming it from Windows and Linux. The firmware is now 4.14.1-0-gdea1347. I can't remember whether the Linux app came up with an update or is it possible to manually do an update? I think I did an update at some point. But I may be wrong. Anyway it is working now and yes, the Linux app is experimental :-) I'm closing this on my part. Report
