November 20, 2025Nov 20 comment_43136 40 minutes ago, OnSteamDeck said: linux cant detect my remote Use sudo Report
November 20, 2025Nov 20 Author comment_43141 11 hours ago, jason said: Use sudo (skip-app:75918): GLib-GIO-CRITICAL **: 09:07:40.517: g_dbus_proxy_new_sync: assert ion 'G_IS_DBUS_CONNECTION (connection)' failed /usr/lib/libproxy/libpxbackend-1.0.so: undefined symbol: g_strv_builder_unref Failed to load module: /usr/lib/gio/modules/libgiolibproxy.so /usr/lib/gio/modules/libgiognomeproxy.so: undefined symbol: g_task_set_name Failed to load module: /usr/lib/gio/modules/libgiognomeproxy.so /tmp/.mount_skip_aG37KMr/usr/lib/libgnutls.so.30: version `GNUTLS_3_6_3' not found (required by /usr/lib/gio/modules/libgiognutls.so) Failed to load module: /usr/lib/gio/modules/libgiognutls.so ** (WebKitWebProcess:75960): WARNING **: 09:08:05.913: atk-bridge: get_device_event s_reply: unknown signature ** (skip-app:75918): WARNING **: 09:08:07.889: atk-bridge: get_device_events_reply: unknown signature Gtk-Message: 09:10:00.085: GtkDialog mapped without a transient parent. This is dis couraged. Report
November 20, 2025Nov 20 Author comment_43145 3 hours ago, jason said: Did the public version work and not this one? Are you on a steam deck? Neither version. newest beta or the public release are working properly. Yes, As my user name says on Steam Deck. Report
November 20, 2025Nov 20 comment_43146 5 minutes ago, OnSteamDeck said: Neither version. newest beta or the public release are working properly. Yes, As my user name says on Steam Deck. My primary linux machine is a steamdeck. I don't have any issues. Did you change anything, are you running a a different desktop environment than the default KDE? etc. Report
November 20, 2025Nov 20 Author comment_43147 2 hours ago, jason said: My primary linux machine is a steamdeck. I don't have any issues. Did you change anything, are you running a a different desktop environment than the default KDE? etc. I haven't changed anything to my knowledge. The only thing I had to do is reinstall steam OS once. Report
November 21, 2025Nov 21 Author comment_43148 6 hours ago, OnSteamDeck said: I haven't changed anything to my knowledge. The only thing I had to do is reinstall steam OS once. @jasonam I missing important libs to run and connect the Skip 1s remote somehow? How do I fix? Report
November 21, 2025Nov 21 comment_43149 59 minutes ago, OnSteamDeck said: @jasonam I missing important libs to run and connect the Skip 1s remote somehow? How do I fix? I think the lib errors and warnings you can ignore, it's normal. Just to be clear, if you double click it, does it launch the GUI? If it does, can you attach the remote. Then create support files and attach them here. I'll look at the logs. It should have an error that will give us a clue. Report
November 21, 2025Nov 21 Author comment_43156 12 hours ago, jason said: I think the lib errors and warnings you can ignore, it's normal. Just to be clear, if you double click it, does it launch the GUI? If it does, can you attach the remote. Then create support files and attach them here. I'll look at the logs. It should have an error that will give us a clue. it launches the GUI. how do i create support files? Report
November 21, 2025Nov 21 Author comment_43157 flirc20250314.logflirc20251120.logflirc20251121.logWill these work? Report
November 21, 2025Nov 21 comment_43159 2 hours ago, OnSteamDeck said: flirc20250314.logflirc20251120.logflirc20251121.logWill these work? In the terminal, can you type in lsusb and paste the output? Report
November 21, 2025Nov 21 Author comment_43160 18 minutes ago, jason said: In the terminal, can you type in lsusb and paste the output? Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 28de:1205 Valve Software Steam Controller Bus 003 Device 003: ID 13d3:3553 IMC Networks Bluetoot h Radio Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Report
November 21, 2025Nov 21 comment_43161 18 minutes ago, OnSteamDeck said: Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 28de:1205 Valve Software Steam Controller Bus 003 Device 003: ID 13d3:3553 IMC Networks Bluetoot h Radio Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Remote is not showing up at all. Check in another PC. If it doesn't show up, replace the chord. Are you using a USB-C to A adapter, maybe it's not good. Try reversing the cable Check your steamdeck hub, or try without the hub. If it doesn't show up in linux, it's not going to show up in the app. Report
November 21, 2025Nov 21 comment_43164 20 minutes ago, OnSteamDeck said: I'm using USB C 2 C and it powers the device Doesn't necessarily mean data is working. If it doesn't show anything in lsusb, it's not connected to the machine. Try another cable. Try reversing the USB-C connector on the remote side. Does it work in another machine with the same cable? This topic is specifically to help me focus on release candidate issues. I'll create a new thread with these posts and move them there since it's not specific to this release. Report
November 22, 2025Nov 22 Author comment_43166 3 hours ago, jason said: Doesn't necessarily mean data is working. If it doesn't show anything in lsusb, it's not connected to the machine. Try another cable. Try reversing the USB-C connector on the remote side. Does it work in another machine with the same cable? This topic is specifically to help me focus on release candidate issues. I'll create a new thread with these posts and move them there since it's not specific to this release. I forgot something important my batteries corroded the battery terminals and only works while plugged in with a cable. Does this influence it being detected by devices and the Skip 1s App? I've been told you can clean the terminals somehow ? Any tips? Report
November 22, 2025Nov 22 comment_43167 15 hours ago, OnSteamDeck said: I forgot something important my batteries corroded the battery terminals and only works while plugged in with a cable. Does this influence it being detected by devices and the Skip 1s App? I've been told you can clean the terminals somehow ? Any tips? Do you have another machine to test it on? You set it up at one point, when was the last time you set it up? (meaning it was configured on a machine) Report
November 22, 2025Nov 22 Author comment_43168 18 minutes ago, jason said: Do you have another machine to test it on? You set it up at one point, when was the last time you set it up? (meaning it was configured on a machine) The machine I set it in does not detect it either. Report
November 22, 2025Nov 22 comment_43169 2 hours ago, OnSteamDeck said: The machine I set it in does not detect it either. I've got to be honest, given the condition of the remote, being that it's an A05 model, ~2-3 years old, and it wont connect to either machine, I don't think it's worth either of our times trying to fix it. Can I send you a 50% off coupon for a new one? Report
November 22, 2025Nov 22 Author comment_43171 16 minutes ago, jason said: Can I send you a 50% off coupon for a new one? Yes. I'm sad my original backer remote is not working properly. If I plug it to the wall or USB connector it works on the currently set devices. PSA: don't use cheap batteries on your remotes! Report
November 22, 2025Nov 22 comment_43172 9 minutes ago, OnSteamDeck said: Yes. I'm sad my original backer remote is not working properly. If I plug it to the wall or USB connector it works on the currently set devices. PSA: don't use cheap batteries on your remotes! I can probably repair it if you send it in. I caught a bug under extreme conditions. Low voltage, nominal temp, the voltage regulator would get stuck latched. It would only happen if you had batteries and plugged into a computer and unplugged the cable. It was rare where and you'd have to do it over and over to reproduce it. But that doesn't mean it wouldn't happen to yours 40% of the time. These things get multiplied when you mass produce or have subtle variations in chip manufacturing etc. One of the difficult things about hardware. It has to work 100% of the time under all conditions. Some of which you can't imagine to test under. It would leak current from the battery. Not a lot, but basically a constant drain that will never go away, even if it's asleep. The only remedy was removing the batteries and plugging them back in. It could have been the reason for the corrosion. I added a diode to the 6th version of the PCB. I would add one by hand to your board as well as try and replace the springs. But the plastic could get damaged, etc. Report
November 22, 2025Nov 22 comment_43173 16 minutes ago, OnSteamDeck said: Yes. I'm sad my original backer remote is not working properly. If I plug it to the wall or USB connector it works on the currently set devices. PSA: don't use cheap batteries on your remotes! Yes, cheap batteries would do it. I use rechargeable. They don't last as long, but it prevents these issues. Report
November 23, 2025Nov 23 Author comment_43174 8 hours ago, jason said: I can probably repair it if you send it in. I caught a bug under extreme conditions. Low voltage, nominal temp, the voltage regulator would get stuck latched. It would only happen if you had batteries and plugged into a computer and unplugged the cable. It was rare where and you'd have to do it over and over to reproduce it. But that doesn't mean it wouldn't happen to yours 40% of the time. These things get multiplied when you mass produce or have subtle variations in chip manufacturing etc. One of the difficult things about hardware. It has to work 100% of the time under all conditions. Some of which you can't imagine to test under. It would leak current from the battery. Not a lot, but basically a constant drain that will never go away, even if it's asleep. The only remedy was removing the batteries and plugging them back in. It could have been the reason for the corrosion. I added a diode to the 6th version of the PCB. I would add one by hand to your board as well as try and replace the springs. But the plastic could get damaged, etc. I think that happened to me on both of my backer remotes. Brand new batteries would die rather quickly and suddenly the controller would loose power and wouldn't work with any button press it'd take one minute or two for both controllers to regain function. I'd take your word for the repair and the coupon! While you have it update the firmware of the controller to the latest. Report
