September 21, 2025Sep 21 comment_42997 As per title, I have a Manhattan T4-R Freeview box, and but the Skip 1s app only has the T3-R in the menu but that rmeote works the T4-R as well so there is no reason why it shouldn't work, but when I try the activity the TV and soundbar turn on but the TV doesn't switch to the HDMI3 input that the Manhattan is connected to nor does it turn the Manhattan box on. I have it set in the app for the Manhattan to Navigate and Control Medisa/Music and the soundbar for audio, the Power on has the TV in it and HDMI3 input, but there is no power on button in the Skip app for the Manhatten only a Power Off one. Any ideas? Cheers Report
September 24, 2025Sep 24 comment_43012 Hi, I also own a Manhattan T4-R Box, and I recommend using the IR Learning ability to add the Manhattan remote to your Skip app. More details here: https://blog.flirc.tv/index.php/2024/07/16/ir-learning-for-the-skip-1s/ Regarding your HDMI problem, I would try adding a couple of seconds delay to the TV power button in your list of power on actions (before the HDMI3 command gets issued). Report
