Power On/Off
Florarctus
The power button control is not part of built-in profiles and Harmony Flirc profile. You need to program it yourself. I don't know how to do that in Harmony (you need to use some key as a power button for the profile) as I don't have a Harmony. In Flirc you need to use command line utility flirc_util to program the power button:
flirc_util.exe record power
Also you should probably check and upgrade if needed the firmware in your Flirc-SE to the latest RC version available here on the Development forum.
You need to first open the command prompt shell using cmd or powershell. Press Win + R and enter one of them and confirm using enter. Then you need to change directory to Flirc install dir. You should be able to enter the above commands then.
