Sc0rp10 Posted December 23, 2015 Report Share Posted December 23, 2015 Hello,I am using flirc with my fire tv and a harmony 650 remote. All keys and functions work fine when I'm using the fire TV but when I switch to regular TV using either my harmony profiles or just the source button on the Samsung remote flirc sometimes receives key presses which are not meant for it. For instance after watching TV if I switch to fire TV I find that some movie has started on its own because flirc received some unintentional key presses. Keypresses are received both from harmony and the samsung TV remote.Is there a way to find out which keys flirc receives from my remotes and how do I disable or switch them to other keys? Thanks. Quote Link to comment Share on other sites More sharing options...
hhmz Posted February 10, 2016 Report Share Posted February 10, 2016 Hello,I have the same problem. Weird thing is that i can controll kodi with my Samsung TV remote. CEC is disabled on both sides TV and Kodi Box.Is there any workaround how to disable that TV remote cannot controll kodi via FLIRC Usb dongle. Thanks Quote Link to comment Share on other sites More sharing options...
