Long Press Action for Remote Keys and Activity Switching
Hello Jason
Now that I can use the Skip 1s Remote again, Thanks for that, I have a couple of Questions.
1  Is it, or will it be, possible to add a Long Press Action to Remote Keys.
A specific use, for myself, is that when I Press 'i' on the Remote I get the Info Window for Plex, however, I would like to Add a Long Press Action to the 'i' Key on the Remote that Triggers the 'Info' Command of my AVR.
This is something that I am able to accomplish on the Harmony.
2  I think I read somewhere on here that you were looking at the way that Activity Switching works.
At the moment you have to Press the Power Button to Switch Off everything and then Press another Activity Button and the Power Button to Switch on the required Devices.
This seems unnecessary, and it can not be too Good for the Devices either.
For example, I currently have 2 Activities, 'Watch TV' and 'Home Theatre PC'.
Both Activities utilise the TV and the AVR, the only difference is that one uses the Set Top Box and one use Flirc.
At the moment to Switch between the two Activities the TV and the AVR are Switched Off and then need to be Switched On again when the other Activity is run.
Is it not possible to leave the Devices On that are required for the Activity and then just Change the Input on the AVR and Switch On, or Off, any Required, or not Required, Devices?
Then when the System is no longer needed, i.e. Bed Time, Press the Power Button to Switch everything Off.
Hopefully that makes sense.
Thanks
Kevin
