June 20, 20251 yr comment_41244 I'm using a Logitech Harmony 950 remote control with a Flirc Second Generation USB Receiver to control Kodi v21.2 on a Mac Mini 2018. All functions work correctly, but there is a noticeable lag—for example, when pressing a direction key, the image on the screen responds with about a half-second delay. I have tried many settings in the MyHarmony software, including "Input Delay," "Inter-key Delay," and repeated key press options, but nothing has helped. In the MyHarmony software, I selected the vendor "Flirc" with the model "Kodi," while in the Flirc software, I chose "Full Keyboard." I also updated the Harmony 950 to the latest available firmware: version 4.15.330 with hardware version 01.00. Strangely, I used the same MyHarmony configuration and settings with a Logitech Harmony One+ remote control, and the lag almost completely disappears—even though that remote is less expensive. Does anyone know how to eliminate this annoying lag with the Harmony 950 remote? Report
July 24, 20251 yr Author comment_41646 On 7/21/2025 at 9:43 AM, wisokylela said: Even though you have selected “Flirc” and “Kodi” in MyHarmony and “Full Keyboard” in Flirc, the Flirc receiver may have learned commands from the Harmony One+ or a generic profile. It needs to learn specific IR signals directly from your Harmony 950. thanks for the answer. How can I learn a specific IR signal? Do I need to reset the FLIRC USB device first? Report
August 12, 20251 yr Author comment_42620 Thanks, I’m using the latest firmware: $ flirc_util Version: flirc_util.release.v3.27.15+ FW Version: v4.10.5 SKU: Flirc 2.0 [dori] Branch: release Config: release Hash: 0xF7261C8C In the Harmony settings, I have already lowered the inter-key delay. Report
May 4May 4 comment_43488 What you’re seeing isn’t a Kodi or Mac issue—it’s almost certainly how the Logitech Harmony 950 is sending IR signals compared to the older Logitech Harmony One+. The 950 tends to be more aggressive with repeats and timing, which can introduce that “half-second” feel when used with a Flirc USB Receiver (2nd Generation). A few things that actually fix this (not just the usual delay sliders): 1. Reduce repeats in Flirc (this is the big one) Open the Flirc software → go to Advanced and: Disable built-in profiles (to avoid conflicts) Try lowering the inter-key delay (or enabling noise cancellation depending on firmware) Most importantly: re-record your keys very lightly (quick taps). Flirc is very sensitive, and if the Harmony sends multiple repeats, it feels like lag. 2. Change the Harmony device profile The “Flirc → Kodi” profile often causes sluggish behavior on newer Harmony remotes. Instead, try: Add a device like “Microsoft → MCE Keyboard” or “Panasonic TV” Then re-map buttons in Flirc manually This works because those profiles send cleaner, shorter IR bursts. 3. Set Harmony repeats to minimum (hidden setting) In MyHarmony: Go to device → troubleshoot → “device responds too many times” Set repeats = 0 or 1 (default is often too high) Even if you already tweaked delays, repeats are the real culprit here. 4. Turn off Harmony 950 “long press” behavior The 950 sometimes adds a built-in hold before repeating keys. You can: Reduce or disable “press and hold” actions in button customization 5. USB polling / macOS side (less common but worth checking) On your Mac Mini (2018): Try a different USB port (avoid hubs) Make sure no other IR/keyboard software is interfering Why the One+ feels faster The Harmony One+ sends simpler IR signals with fewer repeats. Ironically, that makes it feel more responsive with Flirc, which prefers clean, single presses. Bottom line The fix is usually: Use a different Harmony device profile + set repeats to 0/1 + re-record keys in Flirc That combination eliminates the lag in most setups. Report
