April 20, 20251 yr comment_40637 I created Flirc integration plugin for HomeSeer https://forums.homeseer.com/forum/hs4-products/hs4-plugins/audio-video-infrared-plug-ins-aa/ak-flirc-alexbk66/1706867-ak-flirc-plugin-introduction-configuration#post1706872 I'm using FlircWrapper for C# which loads appropriate libflirc and libir based on OS architecture https://github.com/iXyles/flirc-web-remote/blob/main/FlircWrapper/FlircLibraryWrapper.cs https://github.com/iXyles/flirc-web-remote/blob/main/FlircWrapper/IrLibraryWrapper.cs But there's no case for LINUX Arm (which is Rpi 32 bit). So my question is - where can I find libflirc.so and libir.so for LINUX Arm? I installed Flirc software on my test RPi, but there's no libs? sudo find / -name "*flirc*" /run/udev/links/\x2finput\x2fby-id\x2fusb-flirc.tv_flirc_81D01761514D50364E4C2020FF0C2941-if01-event-kbd /dev/input/by-id/usb-flirc.tv_flirc_81D01761514D50364E4C2020FF0C2941-if01-event-kbd /etc/udev/rules.d/99-flirc.rules /home/homeseer/flirc.latest.armhf.tar.gz /home/homeseer/Flirc-3.27.16-armhf/flirc_util /home/homeseer/Flirc-3.27.16-armhf/flirc_3.27.16_armhf.deb /usr/share/doc/flirc /usr/share/doc/flirc/flirc_util.1 /usr/bin/flirc_util /var/lib/dpkg/info/flirc.md5sums /var/lib/dpkg/info/flirc.conffiles /var/lib/dpkg/info/flirc.list Report
May 13, 20251 yr comment_40850 On 5/7/2025 at 5:03 AM, alexbk66 said: Not much activity here in the forum? I'll definitely return to this shortly when I get out our recent updates. I can't thank you enough for your efforts. Will connect with you outside the forums as welll. Report
