Flirc Skip Remote Not Registering Long Press Commands
Hello
I have been setting up my Flirc Skip remote & while most of the buttons work fine, I’ve noticed that long-press commands aren’t being recognized properly. For example; I tried mapping a long press for volume control and input switching, but the remote only registers a single press instead of holding the command. This happens across multiple devices, so I don’t think it’s just an issue with my TV or receiver.
I have checked the Flirc software settings; ensured the firmware is up to date, and even tried reprogramming the buttons with different delay settings, but no luck. Some users mention adjusting IR repeat settings or modifying the key mapping manually, but I’m not sure where to start troubleshooting. Could this be a firmware limitation / is there a workaround to get long-press functionality working consistently? Checked
Has anyone else experienced this? Are there specific Salesforce Admin settings in the Flirc configuration tool that can fix this issue? Any help or suggestions would be greatly appreciated!
Thank you !!
Edited by Lucia
