February 19, 20251 yr comment_39844 Hello Jason I am using Version 0.9.994 (Build 9468) of the Skip App. I Factory Reset my Remote due to some Issues where it was not Transmitting any Signals to any of my Devices. I have Setup it up again, from Scratch but have some Issues. I have Added the following Devices: LG TV (Group 1) Marantz - NR/SR Main Zone All Models Flirc (KODI) When I Press the Power Button on the Remote, the AVR Switches Off then On again, or On then Off. If I go through the Wizard and Test the Power Toggle Button it works as expected, i.e. the AVR Turns On, or Off and stays in that State. I have tried the 'Essential Commands Only' version of the Marantz Device with the same Issues. I have just Tested another Activity and this Issue also happens with the BT Vision Set Top Box. Pressing the Power Button on the Remote Turns On the Set Top Box but it then immediately Turns Off. Any suggestions? Thanks in advance Kevin Edited February 19, 20251 yr by Kevin Cowans Report
