tonytiger999 Posted May 3, 2015 Report Share Posted May 3, 2015 Hi, Just purchased this great product , but having a small issue with power on.I can power off OK (using KodiBuntu) with a standard RC6 MCE but it will not power on! Motherboard is a dh67cf and i have the extra cables connected (power pass thru etc).All buttons are working fine in kodi and have upgraded to 3.6 firmware. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
shimsim Posted May 5, 2015 Report Share Posted May 5, 2015 Does your motherboard supply USB power in OFF state ? 1 Quote Link to comment Share on other sites More sharing options...
yawor Posted May 5, 2015 Report Share Posted May 5, 2015 Shimsim is probably right. You have to make sure that the motherboard is able to supply power to the USB devices in S5 state (full power off). There may be an option in the BIOS for that. Quote Link to comment Share on other sites More sharing options...
tonytiger999 Posted May 5, 2015 Author Report Share Posted May 5, 2015 Hi, Thanks for comments , i thought i could be that i will need to find my Multimeter , the motherboard (Intel DH67CF) does power on/off from a cir (inset) but i cannot fit this it in my new streacom case! Quote Link to comment Share on other sites More sharing options...
