A little thing - Separate auto-repeat setting for cursor keys
Thanks for Flirc, it's an awesome little device!
One of the few issues I've had however is with navigating lists quickly by emulating cursor keys. I believe this is partly down to the remote being used as another remote I tried (with Flirc) worked quite well, but it would help if I could set a faster auto-repeat for the cursor keys. Currently I would like a 0 repeat delay for the cursor keys but this introduces unwanted repeats when using enter or back so I have to leave it at 1 or 2.
Thanks.
The delay is not introduced by the Flirc itself but by the operating system's keyboard settings. Flirc just tells the OS that key is held pressed and when it is released. Until you can set these params separately for cursor keys in your OS I think there is nothing that can be done on the Flirc side.
