Sony STR-DN1080 AV Receiver and Philips 55POS9002 TV
I've tried the generic options that are shown in the app for my Sony Receiver but nothing worked.
For my TV, Code Group 1 did work for power on/off, but perhaps was slightly different to my TV remote which when turned off shows a red LED (to show in standby mode) which doesn't happen using the Skip 1s. Also no other buttons seemed to work, like settings/menu/up/down etc.
I do have the FLIRC usb dongle so here are the codes generated in the device log when I press the various buttons I need, if this helps at all. Note the codes are different each time I press the button, but that may be normal. If I can provide anything else let me know. Thanks.
Philips 55POS9002 TV Power on/off button:
-48618000
+2714 -815 +515 -785 +514 -339 +515 -340 +514 -777 +897 -410 +515 -339 +515 -339 +515 -339 +514 -340 +515 -339 +515 -339 +515 -339 +514 -339 +515 -339 +515 -339 +514 -340 +896 -405 +515 -784 +515 -339 +515
Sony STR-DN1080 Power on/off button:
-4026000
+2455 -490 +1206 -545 +611 -544 +1206 -545 +635 -520 +1233 -518 +610 -544 +610 -546 +610 -544 +610 -545 +611 -544 +610 -545 +1206 -545 +1213 -513 +635 -519 +610
-22000
+2456 -488 +1208 -543 +637 -543 +1183 -544 +635 -520 +1207 -543 +610 -548 +633 -518 +612 -544 +611 -544 +611 -544 +634 -537 +1190 -544 +1213 -514 +633 -521 +610
-22000
+2454 -491 +1207 -544 +611 -544 +1207 -544 +635 -520 +1207 -544 +610 -544 +610 -544 +610 -545 +611 -543 +611 -544 +611 -544 +1231 -519 +1213 -514 +611 -544 +636
-21000
+2400 -545 +1207 -544 +635 -519 +1207 -545 +636 -518 +1232 -494 +634 -521 +666 -514 +635 -519 +610 -545 +611 -519 +640 -539 +1233 -493 +1234 -517 +611 -544 +610
-21000
+2426 -519 +1207 -519 +610 -545 +1261 -490 +611 -544 +1207 -544 +610 -544 +635 -520 +636 -519 +637 -518 +636 -518 +637 -518 +1207 -544 +1207 -544 +636 -519 +591
Sony Sony STR-DN1080 Volume Up:
-36735000
+2342 -603 +552 -578 +1149 -603 +610 -545 +552 -604 +1148 -604 +551 -604 +552 -603 +552 -604 +551 -604 +552 -603 +552 -603 +1149 -603 +1149 -603 +576 -579 +532
-23000
+2392 -554 +602 -553 +1197 -555 +602 -553 +602 -554 +1198 -554 +602 -554 +601 -554 +601 -554 +601 -555 +600 -555 +600 -555 +1172 -580 +1172 -554 +600 -556 +601
-22000
+2343 -602 +600 -555 +1150 -603 +601 -554 +602 -553 +1151 -602 +602 -529 +581 -599 +602 -553 +603 -553 +602 -553 +602 -554 +1162 -590 +1129 -598 +604 -552 +603
Sony Sony STR-DN1080 Volume Down:
-12587000
+2369 -575 +1175 -575 +1185 -542 +639 -540 +551 -604 +1184 -542 +578 -576 +638 -518 +550 -604 +550 -604 +551 -604 +611 -568 +1183 -543 +1147 -603 +551 -603 +560
-22000
+2365 -579 +1173 -578 +1128 -598 +582 -598 +602 -553 +1127 -599 +626 -528 +581 -573 +603 -552 +602 -552 +603 -552 +581 -598 +1128 -598 +1198 -553 +603 -552 +531
-21000
+2365 -579 +1172 -579 +1128 -598 +582 -598 +600 -554 +1129 -598 +599 -555 +581 -574 +598 -556 +600 -555 +599 -555 +582 -598 +1128 -598 +1149 -602 +602 -553 +601
Sony STR-DN1080 input Up selector:
-65338000
+2428 -518 +1230 -521 +611 -520 +639 -541 +1236 -490 +611 -545 +1233 -519 +1209 -543 +637 -518 +611 -544 +638 -517 +612 -544 +1207 -544 +1208 -544 +612 -519 +1235
-20000
+2402 -519 +1234 -518 +637 -519 +635 -520 +1233 -519 +635 -521 +1230 -521 +1234 -518 +635 -520 +638 -517 +637 -494 +665 -515 +1209 -519 +1233 -518 +637 -519 +1186
-20000
+2401 -544 +1234 -519 +610 -545 +637 -518 +1230 -522 +610 -545 +1212 -515 +1234 -518 +610 -545 +637 -518 +638 -517 +636 -519 +1208 -544 +1231 -521 +610 -545 +1185
-20000
+2380 -541 +1233 -520 +611 -544 +611 -544 +1208 -544 +637 -518 +1212 -515 +1234 -519 +636 -518 +612 -544 +610 -545 +665 -490 +1231 -521 +1208 -544 +611 -544 +1187
Sony STR-DN1080 input Down selector:
-33781000
+2381 -538 +608 -547 +1204 -547 +608 -546 +1203 -548 +608 -546 +1205 -545 +1206 -560 +594 -547 +608 -521 +623 -531 +667 -513 +1214 -513 +1204 -546 +608 -547 +1188
-21000
+2398 -546 +607 -548 +1205 -547 +608 -547 +1203 -548 +608 -521 +1204 -547 +1205 -547 +582 -572 +607 -548 +605 -550 +605 -549 +1204 -547 +1204 -547 +582 -573 +1187
-20000
+2367 -582 +573 -549 +1201 -549 +667 -488 +1178 -573 +582 -573 +1177 -573 +1179 -573 +605 -549 +581 -574 +581 -574 +580 -574 +1177 -574 +1212 -514 +581 -574 +1177
-20000
+2369 -551 +579 -576 +1175 -576 +578 -577 +1175 -575 +551 -604 +1174 -577 +1174 -577 +550 -604 +551 -604 +551 -579 +611 -568 +1147 -579 +1147 -604 +551 -603 +1157
I actually got the Sony working by finding a relevant STRDN entry when using the MISC brand, just had to manually map some buttons which was easy enough.
Also, the TV seems to be working fine now, so all good
