alittlebitloki. Posted February 23 Report Share Posted February 23 I cannot find any compatibility with Sky Glass. Without this, the device is of no use to me. Please help! Quote Link to comment Share on other sites More sharing options...
jason Posted February 25 Report Share Posted February 25 On 2/23/2023 at 7:38 AM, alittlebitloki. said: I cannot find any compatibility with Sky Glass. Without this, the device is of no use to me. Please help! We’ll figure it out. If you go into misc. as a device category, it lists everything. There are a number of sky devices. Can you try those? If not. I’ll get them added. I found some codes online, but without a remote, I’ll need a bit of help confirming. Quote Link to comment Share on other sites More sharing options...
alittlebitloki. Posted February 26 Author Report Share Posted February 26 Thank you for your response. To confirm, I have gone through all of the Misc Brands that contain the word sky and tested each of them. None of them work. Thank you for your attention in this matter. If it helps, this is a link to a replacement Sky Glass remote. Just in case it enables you to program the Skip 1S this way. Quote Link to comment Share on other sites More sharing options...
jason Posted February 28 Report Share Posted February 28 It does, I'll purchase one, but I will put a lot of effort into making this easy for customers. If it's adding a bunch of codes with a text file, pointing and recording keys, or pointing and doing a reverse lookup with the original remote. This is my biggest priority. This is not a product that we're shipping and going to work on the next one. We will continue to support and make this product better. Hang tight while I try and quickly help resolve this. 1 1 Quote Link to comment Share on other sites More sharing options...
jason Posted March 11 Report Share Posted March 11 I did some more digging, and it looks like you can put the remote into IR mode. I'm going to grab one and get the codes. I can't find them anywhere else online. Quote Link to comment Share on other sites More sharing options...
jason Posted Friday at 07:54 PM Report Share Posted Friday at 07:54 PM Finally came. Try the attached using the instructions on the first post. Please let me know. Sky - Glass.json Quote Link to comment Share on other sites More sharing options...
alittlebitloki. Posted Monday at 10:41 AM Author Report Share Posted Monday at 10:41 AM Thank you for your efforts Jason and for the update. As I’m unable to access this forum from any device other than my smart phone, I am responding here. I have downloaded the json file but cannot find the instructions you made reference to in respect of adding this file/syncing it to the controller. Please share these in this thread. Once I have received the instructions and run a test, I will also add to the thread. Many thanks. Quote Link to comment Share on other sites More sharing options...
jason Posted Monday at 02:38 PM Report Share Posted Monday at 02:38 PM 3 hours ago, alittlebitloki. said: Thank you for your efforts Jason and for the update. As I’m unable to access this forum from any device other than my smart phone, I am responding here. I have downloaded the json file but cannot find the instructions you made reference to in respect of adding this file/syncing it to the controller. Please share these in this thread. Once I have received the instructions and run a test, I will also add to the thread. Many thanks. Sure thing. Here I show how to import a file, we need to enable admin mode. I will create a more public way of doing this within the app soon; Quote Link to comment Share on other sites More sharing options...
