Two devices one remote control
gordone
Not at all.
As long as both devices are in sight of your remote, they will react on commands.
To avoid this, you only can unplug the flirc device or the ATV, depending on wich device you want to be active.
What are you using the ATV for? If you're running a xbmc destribution on your rpi, your ATV can be possibly needless, due to that Airplay can be enabled in xbmc.
Not at all.
AirPlay in XBMC is not reliable, at least under Frodo, and doesn't support mirroring if that is important.
Philip
