Ommand 0 Report post Posted February 25, 2014 So my flirc arrived in the mail today and I'm having an issue with it. Repeated key response is unacceptably slow and if I push a button on my remote thrice in quick succession it skips 9-12 menu entries. I've gone through a few dozen hopelessly outdated forum threads hoping to find a solution with no luck. I've fiddled with the repeat settings and interkey delays with no appreciable difference. If I abandon the flirc entirely and use the generic IR receiver I have everything works fine perfectly, unfortunately the number of keys I'm able to set with it are very limited due to the receiver not being RC6 compliant. I'm using firmware 2.3 and have the "flirc xbmc" device added in the harmony software. Any help would be much appreciated. Quote Share this post Link to post Share on other sites
Nobuddy0816 6 Report post Posted February 26, 2014 So you're using a wmc (ir6) compliant profile with your harmony? Did you mapped every button twice? this is necessary,due to the wmc protocol sends a second command on every second keypress. Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 26, 2014 Is the "flirc xbmc" profile rc6 compliant? I have no idea. Quote Share this post Link to post Share on other sites
Nobuddy0816 6 Report post Posted February 27, 2014 Me too :D I had a focus on RC6 (or is it iR6... i'm not sure), so i had the ir6 related issue in mind. However, just try it anyway... Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 27, 2014 How would I go about mapping a button twice? I push the remote button and the gui immediately detects it and says it's been mapped. Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 27, 2014 Could the firmware upgrade be a factor? It hung for 15 or 20 minutes before I killed it and plugged the flirc back in. Afterwards it was detected as version 2.3 so I figured it was fine. Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 27, 2014 Looks like the issue is this damned harmony. For some reason it doesn't want to abide by the repeats=0 zero settings for either "flirc xbmc" or the panasonic tv device that has been suggested in other threads. It works fine if I use the IR codes for my receiver or tv (for testing on my windows pc) but that obviously isn't an option in my living room as it will result in loads of conflicts. Quote Share this post Link to post Share on other sites
ytsejam1138 1 Report post Posted February 27, 2014 I had the same problem with my Harmony 700. Here was my solution: It all works smooth as butter now. Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 27, 2014 Yea that's not even remotely a solution for my issue. Thanks though. Quote Share this post Link to post Share on other sites
ytsejam1138 1 Report post Posted February 27, 2014 It will fix your repeated key delay issue. Quote Share this post Link to post Share on other sites
Ommand 0 Report post Posted February 28, 2014 If I unbind the keys in the manner you're suggesting when I try to map the key in flirc nothing at all will happen, as pressing the button on the remote will not produce any output. I use a harmony smart control, perhaps it's different from whichever harmony you have in mind. Quote Share this post Link to post Share on other sites
ytsejam1138 1 Report post Posted February 28, 2014 Ahh, you might be correct. I must be a problem with how the smarthub handles IR commands. Quote Share this post Link to post Share on other sites
