BigEd781 Posted February 22, 2014 Report Share Posted February 22, 2014 I searched around and didn't find anything. I am using a Tivo Premiere remote with XBMC. Flirc software up to date. When I originally programmed my flirc for XBMC, holding down the volume controls would continuously change the volume, as expected. However, after reseting my remote to factory (so that it would cease to also control the television) and reprogramming my flirc, holding down the volume +- buttons changes the volume by only a single increment (as if I had pressed and quickly let go.) Has anyone else experienced this? I have reprogrammed twice now with no luck. Perhaps it's the remote, I don't know, but changing the volume is now a huge PITA. Thanks in advance for any help you can offer. EDIT: Actually, I seem to have lost repeat on hold functionality in all buttons (directions, etc) Quote Link to comment Share on other sites More sharing options...
BigEd781 Posted March 1, 2014 Author Report Share Posted March 1, 2014 Bump. Still having no luck. Quote Link to comment Share on other sites More sharing options...
Nobuddy0816 Posted March 2, 2014 Report Share Posted March 2, 2014 Did you play around with "interkey delay" in advanced settings? Quote Link to comment Share on other sites More sharing options...
BigEd781 Posted March 2, 2014 Author Report Share Posted March 2, 2014 I did, but perhaps not enough. I lowered it, but I'll play around with it some more tonight. Thanks. Quote Link to comment Share on other sites More sharing options...
Nobuddy0816 Posted March 3, 2014 Report Share Posted March 3, 2014 It might be a bit uncomfortable, but it should help if you find the right value, fitting to your needs... Quote Link to comment Share on other sites More sharing options...
MrNice Posted March 4, 2014 Report Share Posted March 4, 2014 Just a tip. You could do a test: If you have a webcam or any video recorder, try to use your remote in front of it. You will see in the recorded video or in video player in you computer the IR emitter flashing when you press the button. At least you will be sure the IR is working. Quote Link to comment Share on other sites More sharing options...
