Antonio Kamiya Posted June 19 Report Share Posted June 19 I am trying to build the SDK on an M1 MacMini 2020 adn here is the results I am getting: xx@tvs-Mac-mini cli % make flirc_util [BUILDING] flirc_util.debug [CC] src/main.c [CC] src/prepost.c [CC] lib/logging.c [CC] lib/getline.c [CC] lib/dict.c [CC] lib/cmds.c [CC] lib/cmds_script.c [CC] lib/cmds_shell.c [CC] src/cmds/version.c [CC] src/cmds/flirc_cmds.c [CC] src/cmds/ir_transmit.c [LINK] buildresults/Darwin_arm64/cc/flirc_util/debug/flirc_util ld: warning: directory not found for option '-L../libs/Darwin_arm64/' ld: library not found for -lflirc clang: error: linker command failed with exit code 1 (use -v to see invocation) make[2]: *** [buildresults/Darwin_arm64/cc/flirc_util/debug/flirc_util] Error 1 make[1]: *** [debug] Error 2 make: *** [flirc_util] Error 2 I guess the Darwin_arm64 version of the library doesn't exist. I was wondering if there are any work arounds for this. Quote Link to comment Share on other sites More sharing options...
