Langis Posted April 22 Report Share Posted April 22 (edited) I have a Fire Tv Cube that I mostly use to turn on my TV and Receiver and switch them to the correct inputs. I mostly use my HTPC for everything. My plan is: 1. Plug the Flirc into my HTPC 2. Program the Flirc to understand Fire Tv Remote's button presses (e.g. HTCP controls, left, right, up, down, enter, back, etc...) Use case is: Use Fire Tv remote to turn on TV and switch inputs (this is using Fire Tv Cube's functions), then use Fire Tv remote to interface with my HTPC. Is that possible? Edited April 22 by Langis Quote Link to comment Share on other sites More sharing options...
Nathan Posted August 2 Report Share Posted August 2 On 4/22/2022 at 12:38 PM, Langis said: Use Fire Tv remote to turn on TV and switch inputs (this is using Fire Tv Cube's functions), then use Fire Tv remote to interface with my HTPC. Is that possible? Seems like the problem with this method is that you couldn't stop the Fire TV from listening, so every command you sent to the HTPC would also go to the Fire TV. Easier solution is to use a universal remote, like the Skip 1s by Flirc, then use that to control everything. Then the Fire TV and HTPC could each have unique commands. Quote Link to comment Share on other sites More sharing options...
