Flirc-SE and power-on in S5
atohmdiy
I am pretty new to lirc and htpc stuff. I build a htpc with a asrock x570 phantom itx tb3, ryzen 4350g, streamcom F7C, streamcom nano160 psu and flirc-se (hard to find but streacom sent me one).
I use manjaro xfce as base, plus kodi with mpv as player.
I tried today to make my remote to work. First when i start flirc guy in xfce it asked to update to latest firmware. I did it and then i map my buttons, including the power button of my remote under the "streamcom" tab.
I check my bios, and there is a few option under the "ACPI Configuration" :
Suspend to RAM =} Auto
Deep Sleep =} Disabled
USB Mouse / keyboard power on =} Enabled
RTC Alarm Power On =} Disabled
And... when my htpc is off (S5) the power button of my remote do not start it. I also own a k400 bluetooth keyboard, it has a power on button with FN + inser key. If i understand it right, it should also power one my htpc as the bluetooth dongle is usb, but it doesn't.
I made some research and the only topic i found is this one : http://forum.flirc.tv/index.php?/topic/1651-power-toggle-triggering-with-streacom-version/
So i try this command to see what is happening :
[satan@satan-mabite ~]$ flirc_util settings
flirc_util version 3.22.4 [3.22.4]
Firmware Detected
Version: v3.9.0
   SKU:     flirc-se
   Hash:    0xE31E4C1A
Settings:
 sleep detection:  Enabled
 noise canceler:    Disabled
 inter-key delay:  5
 seq. modifiers:   Disabled
[E] lib/libflirc/bootloader/bl_2.0.c fl_ver2_product_type(526): unknown or unsupported variant: 144
 variant:          Unknown
 builtin profiles: Enable
Memory Info:
 keys recorded:  12
 keys remaining: 157
 memory used:    8%
 product sku:      flirc-se
Recorded Keys:
Index  hash        key
   0  CC51519B    a
   1  999F59B    up
   2  4AD759B    down
   3  905F759B    left
   4  5B8F639B    right
   5  2FD8079B    power
   6  CDFD879B    return
   7  6C12F59B    escape
   8  3318519B    ;
   9  1FF2F59B    p
  10  60C13F9B    j
  11  F09DD19B    o
The 5th key is well assigned to the power key but there is this "144" error.
Any idea ?
Regards
