Xiaomi Laser projector - might flirc be the solution
jbay
Hi guys,
I own the non 4K international version of the Xiaomi  laser projector   mjjgyy02fm since a couple of weeks. I'm also using a Fire TV Stick 4K instead of the pre installed android 8.1 software for any kind of streaming (Netflix...).
As far as I know it is not possible to boot directly to the fire TV stick.
As a workaround I would like to use my Logitech harmony hub with a script to switch directly to the fire TV stick after booting android but:
1) Issue switch on button.
There is no profile in the harmony database for the international version mjjgyy02fm.
As a workaround tried to use the Nvidia shield TV profile  from the harmony database but the switch for turning the projector on is not available.
As a workaround for the missing on button I made a script with switching on the fire TV stick first. Idea is to use the CEC signal which should switch the projector on. But it works more or less in 1 of 10 times.
2) Issue: Select different source
The Nvidia shield profile which I'm using for the harmony, doesn't contain a "source selection" button. But this is mandatory to me because I don't wanna use the android surface (missing Netflix...). Instead of this I would like to use the Amazon fire TV stick which is assembled to input HDMI 2 of the projector.
Today I got a hint that flirc might be a solution. But before buying this little peace of hardware I would like to get an info if this might work with the Xiaomi Laser projector.
Idea would be:
1. Assemble flirc to projector
2. Connect and configure flirc with harmony
3. Switch on projector via harmony/flirc combo.
4. Select HDMI2 as source
5. Use fire TV stick with harmony
Many thanks in advance and best regards from Germany
