DJ8ones Posted February 24, 2019 Report Share Posted February 24, 2019 (edited) Setup: Flirc SE, Logitech Harmony 650, Windows 10 I'm trying to perform initial programming of the Flirc SE. The only command that seems to work is the one that doesn't use USB (i.e., the power switch). I've tried to program a few other keys on the full keyboard profile and none seem to do anything. What's strange is that the programming step appears to work just fine. For instance, I use Flirc software to program the J key with my desired remote command. Flirc software gives the recorded successfully status. I try to use the J command afterwards and it doesn't work. Tried several keys, all the same effect. The key appears to program, but doesn't do anything afterwards. Closing Flirc software and/or rebooting PC has no effect. I also tried installing Flirc again. It seemed to reinstall without issue. Edit: Just tried Passmark Keytest to check the raw key presses. Nothing registers. At this point, my assumption is that I'm doing something wrong, possibly stupid. Please advise. Edited February 24, 2019 by DJ8ones extra info Quote Link to comment Share on other sites More sharing options...
dannyc211 Posted March 2, 2019 Report Share Posted March 2, 2019 Mine has been working perfect for months and I now have this exact problem. Please somebody help Quote Link to comment Share on other sites More sharing options...
