DanVM Posted November 21, 2018 Report Share Posted November 21, 2018 I own the Shield TV 16GB 2nd Gen and the Shield TV Pro 2nd Gen (I'm not using the Flirc with the Pro as it has a built-in IR receiver). I struggled for some time to properly set up the Flirc and Harmony 650 but have found a solution that has worked for me. This is what works for me: Run the MyHarmony app. Add the device: Manufacturer: Nvidia Model: Shield The MyHarmony app will ask if it is the NVIDIA SHIELD TV. Tell it "Yes" and you should see a full array of options for the buttons. Program the MyHarmony remote's activities and buttons as desired. Adjust the Shield TV's "start" activity to include: Shield TV Home command Adjust the Shield TV's "stop" activity to include: Shield TV Back command Shield TV Home command Run the Flirc program in connect the Flirc to be programmed. Under "Controllers" select NVIDIA Shield: Program each of the functions. Under "Controllers" select Kodi: Program all functions other than the Shield functions programmed earlier. Quote Link to comment Share on other sites More sharing options...
