flirc_util.exe delete_index does not work
mprost
Hi there.
As I see here this is a known issue, any update on when this is going to be fixed? You should consider removing the command if it doesn't work, just purchased my first Flirc and I was about to go nuts thinking I was doing something wrong, until I found that thread.
If this doesn't get fixed, how can I delete a button I programmed using a remote I no longer have access to?
Thank you, this seems like a fantastic product.
Cheers,
mprost
  • 1 year later...
  • 1 year later...
