Problem getting started with Flirc
RobT
I recently bought my 1st Flirc USB and I haven't been able to get it to work. Before pairing a remote, I upgraded the firmware. Using the Flirc GUI I've been able to pair my remote with Flirc. The GUI says "recorded successfully" when paring a key. After pairing the remote, I don't know what to do next. It seems the Flirc device should be useable at this point but nothing happens when I try to use it. Everything seems normal inside the Flirc GUI but outside that, I'm not seeing any keypresses. I originally set things up on a Linux PC. When that didn't work, I redid everything on my Macbook. I'm having the same results on both platforms. Am I doing something wrong or is my Flirc device defective?
I've attached the output of the flirc_util settings command.
flirc_settings.txt
