eugene_o
problems with flirc_util
I am having problems running command line flirc_util (v3.9.10) on macOS High Sierra. When I first tried running it I got:
"Library not loaded: /usr/local/lib/libhidapi.0.dylib"
I ran "brew install hidapi", and after that flirc_util would run and print the usage message. Unfortunately, when I tried any other command, like "flirc_util status", I was getting:
"device disconnected, can't run command"
Flirc itself works fine, and the GUI app works too. Could you point me to anything else I could try to make flirc_util work?
Thank you!
Thanks for letting me know. I am using a non public version of hidapi, as there are several bugs that have been addressed in my copy.
Do the following;
cd /Applications/Flirc.app/Contents/Resources
install_name_tool -change /usr/local/lib/libhidapi.0.dylib /Applications/Flirc.app/Contents/Frameworks/libhidapi.0.dylib flirc_util
For those without install_name_tool (mac developer plugins), updated flirc_util attached.
I'll issue an update shortly.
Sorry for the inconvenience.
flirc_util
That command didn't help:
bash-3.2$ sudo install_name_tool -change /usr/local/lib/libhidapi.0.dylib /Applications/Flirc.app/Contents/Frameworks/libhidapi.0.dylib flirc_util
Password:
bash-3.2$ pwd
bash-3.2$ ./flirc_util status
The version you linked to works, thank you!
Create an account
Register a new account
Sign in
Sign In Now
