isp Posted September 16, 2017 Report Share Posted September 16, 2017 Hi, i would like to know if it's possible to disable the Blue LED on the Flirc Streacom Edition. It's very bright and shines through the Streacom Case onto the Wall behind it. Thanks isp Quote Link to comment Share on other sites More sharing options...
yawor Posted September 16, 2017 Report Share Posted September 16, 2017 Hi, No, it's not possible to disable the LED as it's not controlled by the chip but it's connected directly to the USB power line. You can cover it with a piece of some tape. I think few layers of an electrical isolation tape should be able to block it effectively. I'm using that method on some other hardware which also has bright LEDs without the ability to disable them. Quote Link to comment Share on other sites More sharing options...
