Flirc SE compatibility whis Intel Z270 Chipset? - S5 Mode not work
MediaCenterOwner
for my new HTPC I Board last week 2 new Mainboard whis Intel Z270 base Chipset.
The Mainboard has SGX (Software Guide Extension) switch on. Whisout SGX I have not tryed becaus I need this Function.
When I try to configurate my Flirc SE receiver I will not work.
My old Hardware "AMD FM2 " Hardware I have not problem to configurat the S5 Mode after I know the way.
Whis the new Hardware I have following problem when I will  determine the Power On/Off Button for S5 Mode.
When I open the command interface programm  and start "flirc_util.exe" whis Software" Flirc Software 1.35 RC2"
whis following proceed. I can not configurate the S5 Shutdown and start Function and I got the following "Error"
messages and is does not work:
Example:
 Flirc Version 1.35 RC2, firmware 3,60
Microsoft Windows [Version 10.0.15063.250] -----------------------------------------------> Home Version x64
(c) 2017 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Windows\system32>cd  C:\Program Files (x86)\flirc
 flirc_util.exe record power
Then I got the following Information from "flirc_util.exe"
Warning: cannot open USB device Press any button on the remote to link it with 'power'
When I now press the "Power Button" on my Remote control "flirc_util.exe" give me the message
  Succesfully recorded button
and the "Power On/ off " funktion will not work :-(
Flirc Version 2,39/2.60-> Firmware 3,9
The problem is Equel:
Operation System is:
_____________________
C:\Program Files (x86)\Flirc>flirc_util.exe record power
[D] lib/libtransport/libusb.c libusb_dev_open(143): can't open usb device
My question is now:
- Give it currently problems whis "Intel" based Mainboard whis Z270 Chipsat that not work whis FlircSE Remote controls?
- What is the reason for the Information
       - >all other Remote function currendly work well
- What can I do to fix the problem?
Please help me by this problem. I am not shure what is the problem because on my old HTPC Flirc works fine.
Best regards,
Edited by MediaCenterOwner
