igora137 Posted December 26, 2016 Report Share Posted December 26, 2016 There are 2 New Flirc USB, both not working command line tools, on two different computers:c:\Program Files (x86)\Flirc>flirc_util.exe keys Records: NAc:\Program Files (x86)\Flirc>flirc_util.exe settings flirc_util version v2.0.3 [v2.0.3+] Firmware: v4.0.5 [0x98DF4099] Settings: sleep detection: NA noise canceler: NA inter-key delay: NA seq. modifiers: NA variant: Flirc builtin profiles: NA Memory Info: NA Records: NAIn the GUI codes are sometimes written ... but menu item =advanced= not saviing ... I tried to reflash the firmware, use the utility zadig_2.2 ... does not help.??? Quote Link to comment Share on other sites More sharing options...
jason Posted December 26, 2016 Report Share Posted December 26, 2016 The new device has no advanced configuration yet. These will be added soon. What you are seeing looks good to me. Hang in there. I've had to split time between getting orders out and spending time with my family.1. Sleep detection- Done, needs to be vetted before pushed2. Noise Canceler- Not going to be added, algorithm will be improved until this feature is obsolete3. Interkey delay- Not going to be used, this device uses different techniques that weren't possible on the original4. Seq Modifiers- This should already be working and implemented, just can't be disabled yetThe rest are setting information, and will be added. Quote Link to comment Share on other sites More sharing options...
igora137 Posted December 26, 2016 Author Report Share Posted December 26, 2016 Thanks for the answer, jason! But the most important thing - there is no way to know which keys are already programmed :( I hope it will be in the near updating, because without this meaning the device is lost ... Quote Link to comment Share on other sites More sharing options...
jason Posted December 26, 2016 Report Share Posted December 26, 2016 yeah, configuration files are stored completely differently, it's coming. Quote Link to comment Share on other sites More sharing options...
jason Posted January 8, 2017 Report Share Posted January 8, 2017 Thanks for the answer, jason! But the most important thing - there is no way to know which keys are already programmed :( I hope it will be in the near updating, because without this meaning the device is lost ...v2.0.4 has been posted which will allow you to load a configuration from a v1 device on a v2 device. Also, added is the ability to show saved and recorded keys. Let me know if you have any issues. Quote Link to comment Share on other sites More sharing options...
