madmanuel
Please keep us all updated - i have a new HTPC thats been sitting unused for 5 months waiting for this one last fix.
Bought the FLIRC for the advertised wake function and really don't want to look into returning it and using MCE receivers again.
7 minutes ago, jason said:
Can you guys list your hardware, and all peripherals. I'm going to try and clone your setup.
Hello Jason
Sorry I have not been here lately, my health has not been too good.
The v1 is still working perfectly.
As for my hardware, it is as listed below:
ASUS H110I-Plus Motherboard (BIOS 3016)
Intel Core i7 6700
8GB Ram
Samsung EVO 256GB SSD
Windows 10 Home x64 (up to date as of today)
I hope this helps.
Thanks in advance
Kevin
12 minutes ago, Kevin Cowans said:
Hello Jason
Intel Core i7 6700
8GB Ram
I hope this helps.
Thanks in advance
Kevin
What USB peripherals do you have plugged in?
Anyone have a laptop that exhibits this?
Asrock J3455-ITX with integrated CPU J3455 Apollo Lake. Windows 10 x64 ver.1703
Other than Flirc i have only mouse and keyboard both cabled USB, both Logitech.
If you need i could send you a complete log of hardware, tell me exactly what you need.
Happy to help you if needed.
Bye
Edited by Montas
ASUS Z170i Pro Gaming ITX
Intel 6500
Windows 10 x64
GTX 980ti
USB Stuff:
Microsoft Wireless Receiver (For Keyboard/Mouse) - Which can wake my PC
Xbox Controller
The found new hardware audio plays every I wake my computer up re-installing the FLIRC.
I've also got Wake on LAN enabled and that works too
Intel 6500
Windows 10 x64
GTX 980ti
USB Stuff:
Xbox Controller
Anyone in the US willing to send me their system? I'll send it back along with some money for compensation. I worry that I'm going to waist a lot of time duplicating hardware, and have no success. Ideally, someone with a second system that experiences this on both.
we could all pitch in and buythe less expensive motherboard, if you Jason have a compatible cpu. Or we can buy my mobo (Asrock J3455-ITX) with cpu integrated for 100$.
I'm ready to put 10$ or 20$ if needed.
Someone else?
Bye
OT:  Today i have build a nano-arduino ir receiver with relay, only for trigger the poweron's pins on mobo. It 's a good fallback waiting for working Flirc.
But i have faith in Jason :D
Edited by Montas
Intel 6500
Windows 10 x64
GTX 980ti
USB Stuff:
Xbox Controller
Very kind of you. But I worry that I'm going to be waisting weeks trying to repeat it whether it's due to a BIOS difference, setup difference, Windows build difference, peripheral difference. At this point, I'd like to ask someone if they are willing to send mine, in which I'll pay for all certified shipping, and I'll also compensate you $250.00 for the help and time saving.
ok, i understand you, but J3455-ITX is a all-in-one 100$  mobo so there's no additional peripheral other than ram and disk. I'm not using logitech wireless device, and i tried both bios available. i tried both driver from Asrock website, both latest driver from intel website. bye
Okay, great news, I'll order everything for it today.
Ordered all the components. Hopefully I can reproduce this on site. Expect an update about one week from today, everything arrives early next week. @Montas please send me all the details you can.
Windows 10 64 professional?
Any settings after a format?
Can you save your BIOS config and post here?
Send me a picture of all your peripherals, if possible.
What USB connectors is everything plugged into?
Did you install any software after a fresh install?
Any settings after fresh install?
How do you put your computer to sleep/suspend?
How long does it take for sleep to cause this?
Is there any difference between putting the pc to sleep, waiting for hibernation, and just going to hibernation?
I'll add more if I think of anything.
Ok, i can write you all settings or i can send you a TrueImage image with my exact system. I think it will be around 30-40GB. I have enough space in Google Drive but i need few days for imaging and upload.
Bios setting are default except "Wake from USB Keyboard/Remote" ENABLED
Tell me which you prefer.
PS: there's one problem...it's all in Italian language :) I could reinstall in English if you really really really need.
Bye
Edited by Montas
Bye
Got most of the hardware, will start assembling and installing windows tomorrow. Don't worry about uploading anything just yet. Let me see if I can reproduce this on my own first.
I'm having the same issue.
Here is my system configuration :
  • Alienware Alpha R2 (mini PC)
  • Windows 10 Home (with all latest updates)
  • I have a dongle for a wireless Logitech K400+ keyboard in the first usb port in front (see photo)
  • The Flirc dongle is connected to the second usb port in front
  • BIOS configured with "Wake from USB" enabled (I successfully tested the wake function with keyboard connected to the PC)
38 minutes ago, jason said:
I've got the other system up and running @Montas suggested and I've reproduced it. I'm furiously trying to find a remedy and won't stop until I do.
It's a very good news that you have reproduced the problem ;)
Now i'm sure you can do that.
Good work :)
Good work :)
Okay guys, I think I figured it out. I pushed an update, GUI version v2.3.8 which has new firmware in it. So confident, I made it public, however, this may in fact just fix @Montas system. But I'm fairly confident. Seems to be a windows only thing, they send a set remote wake up feature request down to the device, in which case I would send a stall/nack. Windows said, 'oh yeah, fuck you' and then disconnected me. I'm now returning OK. This is not a required feature, apparently windows 10 says it is. Please don't leave me hanging if it works, please report back here and let me know. This was both brutal in finding, repeating, and solving.
  • Like 2
