essential Posted August 15, 2016 Report Share Posted August 15, 2016 I have a Harmony Elite, which doesn't have dedicated number buttons. I'm using a WD TV Live with the Slingplayer.I've added my FLIRC to my Harmony profile, my plan was to manually map full keyboard shortcuts so I could get a 0-9 on the touchscreen since, for whatever reason, Harmony does not give me the number functions on the touchscreen.However, FLIRC doesn't give me 0-9 in the Harmony options, it just lists "Aspect Ratio - Zoom Normal" which is the Kodi profile.The way the Harmony works now, apparently you can only slide things over to the touchscreen that are in the list. Is there a "full keyboard" FLIRC profile on Harmony?I could "teach" the FLIRC the commands but I have no way of getting the 0-9 on the touchscreen it seems unless I can get a FLIRC profile that lists them as well.Thanks. Quote Link to comment Share on other sites More sharing options...
Bob Sutton Posted April 25, 2018 Report Share Posted April 25, 2018 In,Harmony, you can add Device:Flirc, Name or model: Media Player. Then use Harmony to add commands and number pad to it. Use the Kodi profile. Add Flirc to your activity as a device. Then sync Remote. You will at least be adding the numbers. Bob Quote Link to comment Share on other sites More sharing options...
