AWD Posted August 9, 2016 Report Share Posted August 9, 2016 I got everything working properly (sort of).My Flirc is requiring line of sight from my Harmony 900... which is an RF remote.I have an IR blaster mounted right above and its controlling my receiver fine.So why isn't it working on the Flirc... the Flirc does respond if I point the remote at it but this is useless to me as I don't keep my hardware in the same room as the tv.Running Kodi on an Nvidia Shield. Quote Link to comment Share on other sites More sharing options...
jason Posted August 9, 2016 Report Share Posted August 9, 2016 It shouldn't require line of site. Is your IR blaster in range of flirc? Or are you using your harmony for flirc? Quote Link to comment Share on other sites More sharing options...
AWD Posted August 10, 2016 Author Report Share Posted August 10, 2016 Weird things happening... It doesn't seem as if my IR blasters are working at all. I just eliminated my HTPC and built a NAS and added the Shield. This allowed me to eliminate a lot of wiring and also moved a bunch of stuff around. For whatever reason my AV receiver which definitely uses an IR remote works off the harmony with the blasters unplugged. The Denon remote that came with it will not work without line of site. My Playstation is no longer responding to the Harmony. Nothing else requires the blasters. No idea why they are not working all of a sudden... The Flirc is working with line of site but not with the IR blasters... I can understand if one stopped working but I have multiple ones mounted and I seriously doubt they all went bad at the same time. Gonna have to look into this more. Quote Link to comment Share on other sites More sharing options...
