[Problem] Buttons press leads to 2 clicks or none
stage
I recently got my Flirc and have programmed it using using the software v1.3.6I'm using it on XBMC for my Ouya but the problem is that every time I press a button it either acts like I've pressed it twice or it doesn't respond to the press.
It's almost impossible to use. It seems like the keys are too sensitive?
I have tried reprogramming keys and made sure I have a direct line of sight but I've still got the problem. This is the remote I am using Mag 254 Remote
I've heard that you should try recording each button press twice but after I've recorded it once, it brings up a message saying "Button already exists. 'cancel' 'redo'
Could someone please help?
Thank you
Edited by stage
Just found this article and it has helped a bit more with delaying button presses.
It seems like the problem is that the flirc is too sensitive and is sending multiple button presses instead of just one.
I have set Inter-Key Delay to 0 but is there anyway to make it less than that, for example -2? (I know that sounds a bit stupid)
Article image below:
Edited by stage
Thanks, I just tried this and it has slowed the button presses down a lot.
Problem is, it's a bit too slow now so if I press the button to go back and then press it to go back again it won't register because of the delayed input.
I'll have to keep fiddling with settings.
