issues with one for all remote
Hi
I'm using One-For-All remote to control XBMC.
Th Flirc setup was pretty straightforward...however, it seems i wasn't able to input the right definition correctly. every time i use the remote it basically works but it also tries to activate a TV function...
any ideas?
thanks!
You need to set different device code on different device button on the remote. You can't use the same device and device code as for your TV because it WILL control both your TV and Flirc at the same time. Try selecting different brand device for Flirc than your TV is (for example if you have a Samsung TV then choose something from LG or Panasonic for Flirc etc).
