ijourneaux Posted January 29, 2015 Report Share Posted January 29, 2015 I was just wondering if the choice of controller affects how button presses are recorded. For the media center remote, are all of the buttons going to be supported? Quote Link to comment Share on other sites More sharing options...
yawor Posted January 29, 2015 Report Share Posted January 29, 2015 Hi, Controller selection affects only new buttons you record while using that controller. It doesn't affect already recorded buttons, so you can switch between them freely. Every controller (except keyboard and media buttons ones) is just a predefined set of key combinations. If you know exact key combinations yourself then you can also just use the keyboard controller and record them yourself. If you want to learn how controllers are actually configured you can check this page https://flirc.zendesk.com/hc/en-us/articles/202923419-Controller-presets-in-Flirc-GUI. Quote Link to comment Share on other sites More sharing options...
Chris! Posted January 29, 2015 Report Share Posted January 29, 2015 I've been meaning to make a help doc about controllers in the Flirc GUI, it seems to be causing a fair bit on confusion to quite a few users - which is fine :) Does Yawor's reply answer your question? [Edit]: Also I haven't finished the help document, the amazon fire section isn't done (as I don't think it's fully finished at the moment) Quote Link to comment Share on other sites More sharing options...
ijourneaux Posted January 29, 2015 Author Report Share Posted January 29, 2015 Ok. That was the way I thought it worked and that is how I was using the different controllers. The reason for asking was to make sure I wan't contributing to my problems recording buttons by using the various controllers incorrectly. Thanks. Quote Link to comment Share on other sites More sharing options...
