Harmony 700 + Flirc + Raspi Problem....
rainfall
I have a Harmony 700 remote and Flirc on my Raspi.
Through myharmony i already select Flirc XBMC profile....
Now, the issue is; for the first few minutes I can use the remote. after that, the remote cannot be used to control the my Raspi anymore.
Sometimes I need to plug out the Flirc and in again, then it will work for a few more minutes.
Anyway I already used a better Power Adaptor for my Raspi, bought it from modmypi.
Do anyone have this issue???
Will wait for response before I start testing using the TV Profile.
Any help will be appreciated.
It detects the Flirc. i dont see any message saying it upgrade the Flirc though.
Situation is,
I plug Flirc to my Raspi (OpenElec 4.2.1)... use my Harmony with the Flirc XBMC Profile on it.
I can use the Flirc using the remote.
Watch the movie a few minutes, then try to use the remote again, Flirc not responding.
Sometimes I try to plug out the Flirc, and plug it back to the Raspi, remote & Flirc working OK.
But sometimes it will not work, so i need to reboot the Raspi again.
  • 3 weeks later...
