Xubuntu 14.04 Gui problem
linus
Hello, i have just bouth twice Flirc.
So i have followed the information to install it on xubuntu 14.04 64 bit. And so i have got the version 1.2.9 .
As i always put the last stable firmware, i have made an upgrade.
The stick was on 2.1, and after the update it goes to 3.1
I have tested to asign key, and it works.
After that i stop the application and do overthing.
I wanted to add some keyboard key to the stick.
I could not launch the application from the user, it says:
Flirc
Erreur de segmentation (core dumped)
I don't know why my message is not full...
I was saying that after that, if i launch the application from the user, it crash, if i launch it with sudo it works.
I could assign key etc.
IF i roll back to the 1.2.6, i could launch it from user, but could not do anything as the firmware is to new.
I have a got a log of strace from user if you want. I could post it.
An if i do a flirc_cmd status it says that the previous update was not ok. But if fact it is already ok.
