Harmony 1100 AppleTv to control FireTv
Paddy
I've replaced my ATV3 with a FireTV. I've used Flirc and kept the ATV profile on the Harmony as the buttons are quite similar. All works well except the play/pause button.
The ATV profile has separate play and pause buttons whereas the fire tv has just the one dual purpose.  I though no problem I'll just use the play button but this is not working. The Firetv sees the press but it does nothing or its seeing a double press.
Any ideas? is there a better Harmony 1100 profile to use?
You might want to take a look at this fix, it worked for me using the Roku profile for my FireTV with my harmony:
https://flirc.zendesk.com/hc/en-us/articles/202819236
I changed that setting to 0 to fix repeat key presses, it may be that you are getting a play then pause.
You could also try re-recording the keys with the upgraded firmware 3.0 and the firetv mapping and checking for sources of interference if none of the above work
