3.5 or 5.25 inch bay mountable option
jippen
I think it would be pretty awesome to have this available in an option that would fit a standard sized drive bay, and use an internal USB header. This way it could be cleanly installed in a media PC, without having to worry about losing the adapter during moves. It could also be bundled into, say, a "premium" model, that attaches to a hub and spits out a few more front USB ports for convenience. Or a cardreader or something along those lines.
  • 4 weeks later...
I don't know if this is feasible because he would have to get a certain number of units produced. You may have to do it yourself with a front panel header, by taking the actual ports out and installing the Flirc in the slot.
I may try it myself someday. The eSATA port on my panel looks like it's wide enough, but the height will need some expanding. It will take some experimenting to see how far in it can go while still picking up signals from the remote.
