Firmware Question
lostsole
You are running old firmware and gui. You can upgrade firmware from new version of the gui (menu File -> Advanced -> Force FW upgrade). There is always a question that if everything works OK for you then is there a reason to do upgrade. If it works for you don't break it :).
